Problem with STM3210E-EVAL and Flash Programming
hauschij
Posted on July 23, 2008 at 06:33
hauschij
Posted on May 17, 2011 at 12:40
hallo,
can anybody help me. my problem is that the programming of the external flash on the stm3210e-eval is not possible. i tried to programm with DfuSe V2.2 but nothing happend. Than i found the flash loader demonstrator v1.1.1 but this tool is only able to detect the sram und the internal flash.
can anybody help how to programm the external flash?
thanks
ettore
What do you mean that ''nothing happens'' when you try with Dfuse? Does the serial flash appear in the ''select target box'' ? On the B version of the Eval board you need to hold the ''key'' button down then hit reset. The chip will go into DFU mode that way.
ettore
hauschij
it doesn't appear in the window. and i also tried to key button, nothing happend...
