PB8/9 interfering with each other when using timer/AF
jordanjohnp
Posted on October 16, 2014 at 17:17
The original post was too long to process during our migration. Please click on the attachment to read the original post.
Posted on October 16, 2014 at 19:06
I'm not aware of a GPIO/AF conflict on F1 devices, you could check the errata, which as I recall has a couple of peripheral/peripheral conflicts on the some pins in AF mode. What other peripherals have potential claim to PB8 and PB9?
Other than that look for mundane causes related to solder/circuitry attached to the pins externally, paths there, and if you can replicate behaviour on a VL-Discovery board.
jordanjohnp
Posted on October 17, 2014 at 16:55
Thank you for your comments. As you said, the problem was external hardware circuitry.
