Max232 level shifter
‎2013-07-05 3:02 AM
hello
i have usb <-> R232 converter and i want to make it receive correct characters from stm32f4 board , so which capacitors i have to use with max232 to realise this ? and thnx :)- Mark as New
‎2013-07-05 7:50 AM
What does the part documentation tell you about the voltages and capacitors?
‎2013-07-05 8:43 AM
i posted in other forum and many answered that u can control output voltage by changing the value of capacitors . so if it's wrong , can u propose for me a solution ?
‎2013-07-05 10:56 AM
You can use anyone between 100nF ~ 1uF. It can be changed with the distance and the amount the noise of enviroment. Only be carefull, MAX232 need a voltage supply of 4.5V to 5.5V and most stm32 boards are using 3.3V regulator. Maybe will be better use a MAX3232 that support a voltage supply of 3V to 5.5V.
‎2013-07-05 11:03 AM
thnx so did u tried before that marge of capacitors values 100nF ~ 1uF with max232 to interface stm32f4 and and pc via usb <-> r232 adapter ?
‎2013-07-05 11:09 AM
Because generally they meant by it the level +/-12v for the rs232 <-> r232 cable
‎2013-07-05 12:12 PM
The MAX3232 w/0.1uF parts at 3.3V is much more likely to have outputs closer to +/-6V, which would meet EIA/TIA-232-F and EIA/TIA-562
http://pdfserv.maximintegrated.com/en/ds/MAX3222-MAX3241.pdf
If you read the documentation you'd be able to do the design work yourself, rather than ask questions that demonstrate you haven't.Up vote any posts that you find helpful, it shows what's working..
‎2013-07-05 12:51 PM
thank you clive i hope it will work :)
