LIS302DHL MEMS Accelerometer
oz
Posted on December 30, 2009 at 04:19
oz
Posted on May 17, 2011 at 13:35
i work on LIS302DHL MEMS accelerometer, and i want to know how to use it for calculate accurately angles, maybe someone can give me some tips.
thanks.
hbliek
Something like this works. ax,ay&az are the raw readings from the SPI.
Code:
double vect = sqrt((ax * ax) + (ay * ay) + (az * az));
/* Only allow updates during gravity between 0.9 and 1.1G */
if((vect > MIN) && (vect < MAX))
// pitch_r = asin((double)ax / vect);
pitch_r = atan2((double)ax / vect, (double)az / vect);
pitch = (int16_t)((180. * pitch_r) / M_PI);
// roll_r = asin((double)ay / vect);
roll_r = atan2((double)ay / vect, (double)az / vect);
roll = (int16_t)((180. * roll_r) / M_PI);
oz
thanks you, it's very helper me!
