library, taking into account the chip bugs?
seawwh2
Posted on May 13, 2012 at 07:30
Recently found a problem when test the F4 USB: I use the F4 Discovery chip version of 'A', the manual says this version , there are some bugs in USB.  the Lib 2.1.0 ST OTG consider these bugs?
alok472
Posted on May 16, 2012 at 15:53
what kind of problem do you see ?
The 2 problems in Errata are for host mode and 2 for FS mode. Are you using USB-FS ? These are corner cases anyways.
