I2C communication
nanayakkaraan
Posted on November 12, 2010 at 08:07
I2C communication
Posted on May 17, 2011 at 14:14
Please provide the make/part number of the slave device, and the code you are using to initialize and communicate with the I2C bus.
nanayakkaraan
It is STM32L152
thanks.
It is STM32L152
NO THE SLAVE DEVICE
If you aren't using the correct address, the I2C is not correctly initialized, or the part is simply not wired correctly, then the SLAVE device will NOT respond, there will be NO ACKNOWLEDGEMENT FOR IT.
