I am using FREEMODBUS with stm32f3xx . My question is how it will recognize the serial port or USART ?
Mitesh
its just have a predefined function
eMBErrorCode eMBInit (  eMBMode  eMode, UCHAR  ucSlaveAddress, UCHAR  ucPort, LONG  ulBaudRate, eMBParity  eParity
how it will take my USART3 to communicate as modbus ?
Pavel A.
Do you have an existing STM32 project or have your own generated with CubeMX or some IDE?
Basically you'll want to use the initialization code created by Cube, with baudrate and other parameters as you need. In the CubeMX options, select Low level library (LL) for the USART, not HAL.
Your eMBInit function body will be no-op, the initialization will be generated by Cube.
Then write send & receive functions and interrupt handler using the LL library.
-- pa
