how to download my JAVA application to STM32F429 eval board
aizhixi
Posted on December 27, 2013 at 02:31
hello :
i  can download my java application to STM32F407 eval board, i saw STM32F429 also supported it on www.is2t.com .
however,on IS2T'S website i found not STM32F429 EVAL board on the java kickstart platform,you know .
i download the MRCROEJ software, at the same time ,the platform also didn't supported STM32F429 ,i know about the different between the STM32F407 and STM32F429,only has the LCD drive has some difference.right?so how i should to deal with it .
thanks so much.
BEST REGARDS
ROY
vincent.philippe
Posted on January 02, 2014 at 12:22
Hi Roy,
Thanks a lot for your question!
Yes , that's right the LCD driver is different, but it's not the only difference: other important point: The evaluation board harware is new with new LCD , new Touch sence, external memory etc...
So, you need new low layer environment. This will be delivery in the new MICROEJ 2.0 .
 best regards
Phil
