2016-05-09 12:30 AM
Why Lan8720A is usually used with F407, I want to use it with F107, are therelimitations
with F107?2016-05-09 2:40 AM
Have a look at this , it maybe helpful for you. Regards2016-05-09 6:16 AM
More likely the available parts when it was originally designed. Make sure you can change the PHY address in the code, prototype the circuit you have in mind.
