ERROR MAKE MENUCONFIG
armnguyen
Posted on December 01, 2009 at 09:03
armnguyen
Posted on May 17, 2011 at 13:32
Hi Guys!
I had bouhgt ''STM3210E-EVAL'' board from ST.
I were dowloads the original Uclinux source file from the Uclinux project page
http://www.uclinux.org/,http://www.codesourcery.com/
I am building the Uclinux image and with some errors when
''make menuconfig'':
''[host_nguyen@localhost uClinux-dist]$ make menuconfig
config/mkconfig > Kconfig
CC=cc CXX=c++ make -C /home/host_nguyen/wordspace/uClinux-dist/config/kconfig conf
lxdialog/check-lxdialog.sh: line 9: cc: command not found
make[1]: Entering directory `/home/host_nguyen/wordspace/uClinux-dist/config/kconfig'
cc -DCURSES_LOC='''' -DKBUILD_NO_NLS -c -o conf.o conf.c
/bin/sh: cc: command not found
make[1]: *** [conf.o] Error 127
make[1]: Leaving directory `/home/host_nguyen/wordspace/uClinux-dist/config/kconfig'
make: *** [/home/host_nguyen/wordspace/uClinux-dist/config/kconfig/conf] Error 2 ''
Can you help me? I don't known ,how i do?
Here is my email address:''lehoangnguyen_bd@yahoo.com.vn''.
Thanks a lot!
Nguyen
