2016-10-24 11:50 AM
Hello
Here is my code:void
USART1_IRQHandler(
void
if
(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
if
(DataReady==1 && count<=150){
if
(msg[count]==
'\0'
){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);DataReady=0;}
USART_SendData(USART1,msg[count]);
count=count+1;
if
(DataReady==0 || count>=150){USART_ITConfig(USART1, USART_IT_TXE, DISABLE);DataReady=0;}
if
(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)
temp=USART_ReceiveData(USART1);
if
(temp==65){
Received=1;
bitpos1=0;
else
if
(temp!=66 && Received==1 && temp>47 && temp<58){
bufferu1[bitpos1]=temp;
bitpos1+=1;
else
if
(temp==66 && Received==1)
Received=0;
cop1();
endbitpos1=bitpos1;
SerialFlag=1;
else
if
(Received==1 && bitpos1>150){
bitpos1=0;
Received=0;
else
if
(bitpos1>150){
bitpos1=0;
Received=0;
} Unfortunately when I'm in receiving mode and suddenly I disconnect cable it causes a hard fault for my network connection(Ethernet). How can prevent from being hang when cable has been disconnecting? How can detect this states?
2016-10-24 12:23 PM
Where exactly is it Hard Faulting?
Could you be getting a NULL pointer, and use it without checking? Could you be overrunning an array?Could you perhaps bounds check bitpos1?Can you check the PHY?
