2016-11-30 8:00 PM
Hello Sir, i want to ask how to add 390ns or 0.39us for dead time ?
My systemclock = 64 MHzMy AHB Prescaler = 4so my HCLK = 16 MHzand because of APB1 Prescaler = 1then my APB1 peripheral clocks = 16 MHzSo, what number i should put in the dead time configuration ?Thanks a lot !Solved! Go to Solution.
2016-12-01 6:35 AM
Problem solved.
Deadtime = the value that you want (in my case 390ns) * systemcoreclock(Keep in mind that systemcoreclock is HCLK, not systemclock)So my deadtime would be = 390ns * 16 MHz = 6.24 = 6 or 72016-12-01 6:35 AM
Problem solved.
Deadtime = the value that you want (in my case 390ns) * systemcoreclock(Keep in mind that systemcoreclock is HCLK, not systemclock)So my deadtime would be = 390ns * 16 MHz = 6.24 = 6 or 7We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
