Cube setting for timer in STM32F031 limited to 8 bits, should be 16
mb300sd
Posted on December 28, 2014 at 18:20
I cannot recall for sure whether it was the PSC or ARR, but one was limited to max value 255 when it should have been a 16 bit register. I already edited my xml file to correct it so I could generated the code I needed and can't recall which one had the issue.
0 REPLIES 0
