CS43L22 and discovery board
Options
‎2013-04-12 12:29 AM
Posted on April 12, 2013 at 09:29
Hello
I want to make a Beep sound on the discovery board , but i have problems in understanding the code there , I could make the beep work but only when there its playing audio , i want to make the beep work even if there no audio is playing . Any help here ? Regards Esat
Options
‎2013-04-13 5:05 AM
Posted on April 13, 2013 at 14:05
It won't beep unless it's also receiving data. Therefore you have to ''play'' zero bytes for the duration of the beep to get just a beep out of it.
Options
‎2013-04-15 12:36 AM
Posted on April 15, 2013 at 09:36 Thank you Andy I will try that and will inform you , if i success or not .
