Can't read the documents in nucleo_64pins_sch.zip
LMI2
Lead
Posted on October 26, 2015 at 19:42
I have a NUCLEO-F401RE board. I tried to find its connector pin out, because the schematic diagram is made with some hobby tool and useless. All the doc document files use some odd format I can't read opened. I tried Windows tools like Wordpad and Libreoffice. What I am supposed to use? The pdf file opened all right, but like I said, it does not tell much.
Posted on October 26, 2015 at 21:39
Aren't they .SCHDOC ? From Altium?
http://www.altium.com/
http://www.st.com/st-web-ui/static/active/en/resource/technical/layouts_and_diagrams/schematic_pack/nucleo_64pins_sch.zip
LMI2
Lead
Posted on October 27, 2015 at 18:02
The PDF files loook like they were made with Eagle or Kicad. And anyway, they are not very easy to use. I don't like schematic diagrams where parts are put randomly around the sheet and you  have to search hard to see what is connected where.
But I found those connector pinouts elsewhere. One pdf in Nucleo board page had them.
