Bebugger
hajermarnissi
Posted on March 19, 2011 at 08:32
Bebugger
#!winning-rtfm
samiassaad
Posted on May 17, 2011 at 14:28
I am using Ulink2 , you just insert breakpionts and step throw the code and check you variables and compare them with what you expect , then you can find the problem.
hope it helps .
Andrew Neil
''how
to use the
debugger
Keil
UV4''
RTFM:
http://www.keil.com/support/man/docs/gsac/
http://www.keil.com/support/man/docs/uv4/
http://www.keil.com/appnotes/docs/apnt_197.asp
http://www.keil.com/appnotes/docs/apnt_209.asp
http://www.keil.com/download/docs/373.asp
