STM32L0 - DFU support?
Tantalum
Posted on February 21, 2015 at 19:40
Hello
I just need a confirmation.
Is there really no support for firmware upgrade over USB (DFU) in the STM32L0 MCUs???
The STM32L0 is not listed in the
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00264379.pdf?s_searchtype=keyword%20
document.
But in the CubeMX tool the DFU usb profile can be selected for STM32L0 MCUs.
Is DFU supported or not?
Thank you
#stm32l0-dfu
Posted on February 22, 2015 at 00:00
The 4K ROM in the L053 doesn't seem to be adequate to support USB/DFU.
Perhaps Cube referencing a FLASH based DFU loader?
Amel NASRI
Posted on April 05, 2016 at 18:30
Hi fischbach.paul,
If you refer to table 3 of
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/CD00167594.pdf
, you should find the information that DFU bootloader is available for STM32L07/L08 devices.
Then, AN3156 will be updated to include STM32L0.
-Mayla-
