STM32 as EPROG for ADAU1701
Tomdy
Anyone here had experience use STM32 as EPROG simulation for ADAU 1701 ? Looking for the engineer to validate the firmware’s
7 REPLIES 7
MikeDB
Lead
Could you clarify what you are after ? I've used both STM32s and ADAU1701.
Tomdy
Hi We had problem after MCU EPROG to ADAU1701. The MCU keep send wrong address to the ADAU and ADAU won't boot. Here are some screen shot of I2C . Can you advice ? Thank you so much.
Tomdy
Tomdy
What is this picture taken from ?
And what is the address you think it should be sending ?
Your explanation of this isn't really helping your case. Perhaps diagram what you're doing.
EPROG? EPROM programmer?
You're simulating a ADAU1701? You're connecting to a real ADAU1701?
What is your code doing? What should it be sending? How should the target device be responding.
Ok, and what about the checksum here is at issue?
Describe the issues with context, explaining what should be happening, what is actually happening, and the code that isn't generating the expected results.
People here aren't intimately involved in your project or development process.
