Maxium data rate across Virtual Com Port
Posted on October 25, 2011 at 20:54
Hi all,
I am am currently working on a system whereby we would like to stream event generated data at rates of 100Mbit/s+ across the usb to a debug terminal on the host. We are using the STM32F207 device and its HS USB port. Starting with the example virtaul com port code provided by ST I was able to remove the UART and then access the circular buffer APP_RX_DATA to implement my code. However the data rates I seem to be getting are: 1. varied (im guessing an OS issue on the PC. 2. Reasonably slow 11-14Mbits/s Am I trying to do something that is not possible here? If so is there a better way of doing this? Thanks for your help in advance. #stm32f207-cdc-virtualcom-usb
