is there any example for cdc-ecm host on stm32 mcu with azure rtos via HS? i saw that you provide the drivers but could not see any aplication operating These.... , unlike the st-usbLibrary which is plug and play.
GCohe.1
mohamed.ayed
hi @GCohe.1​  ,
We don't provide yet CDC-ECM Host example or template in our packages
Waiting for that delivery, you may use Microsoft Azure RTOS documentation  in order to develop your own application.
https://learn.microsoft.com/en-us/azure/rtos/usbx/usbx-host-stack-6
GCohe.1
i tried using the azure rtos drivers, but there's also no example for cdc-ecm host with azure rtos to, i'm pretty much lost ...
when you jenerate the files of the usb there is not even basic aplication to run the azure rtos drivers
unlike with the stm32 usb drivers which is plug and play.
