Ethercat master with ethernet capabilities
FBOY3.1
I would like to know if it is possible with a stm32f407 to drive 10 ethercat slave and communicate at the same time with my computer with an UDP protocol (2 ports).
Or if UDP is impossible having multiple serial port, like this I can use an serial to UDP converter.
I saw board with stm32F407 + LAN 9252 are ok for a ehtercat master ?
aliexpress.com/item/1005001284469083.html
or
aliexpress.com/item/32988654470.html
0 REPLIES 0
