Are there STM32 chips that can be programmed over CAN?
MOstl.1
Peter BENSCH
Yes. Please have a look into AN2606, where you will find all related families of STM32 supporting this using the built-in bootloader.
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
Ozone
Principal III
I would suggest a custom bootloader instead.
CAN has quite a lot of protocol overhead, and limited baudrate. I doubt CAN-FD is supported in system BL mode.
So, CAN would be a very sub-optimal choice for programming during the production process.
Thank you very much!
