STSW-ST25R001 GUI Is not installing
angad
When I try to install the GUI ,windows says this: "This app can't run on your PC".
How does one get the GUI up and running? Please advise.
Ulysses HERNIOSUS
Hi Angad,
In the meantime the CMS got changed. I was able to correctly download as zip now. Please check.
If just the error message would be more helpful:
This app can't run on your PC.
To find a version for your PC, check with the software publisher.
doesn't really help to figure out that it's just a wrong suffix. I think this is still an heritage from MSDOS and Win10 made it worse with its new error message.
Regards, Ulysses
6 REPLIES 6
Brian TIDAL
which version of Windows is installed on your PC?
Rgds
BT
angad
Windows 10 Home
Version 1803
Ulysses HERNIOSUS
the message you got is most likely due to the fact that we have moved from .exe content on the web to .zip content on the web. Unfortunately during a short window there was a .exe with zip content which produces this weird/misleading message.
Please try again to download.
Regards, Ulysses
angad
I downloaded the file again. But the problem still persists. Same error as before
Kindly advise
Best,
Angad
Ulysses HERNIOSUS
Hi Angad,
the issue should have been fixed several days ago but still persists. Probably the right incantations for our CMS need to be executed...
For now: Download and change the suffix to .zip manually. Sorry for the inconvenience!
Regards, Ulysses
Ulysses HERNIOSUS
Hi Angad,
Regards, Ulysses
