ST25DV04 WITH STM32WB READ GARBAGE VALUE
NASOK.1
I'm USING ST25DV04 WITH STM32WB THROUGH 12C BUS.IAM ABLE TO WRITE FROM MCU AND READ IT IN APP,AND ALSO ABLE TO WRITE THROUGH APP INTO THE MEMORY,BUT COULDN'T READ THE SAME THING WHAT I WRITE IN THE APP.I CAN ONLY READ SAME GARBAGE VALUE OR ZERO
Ulysses HERNIOSUS
in memoriam Terry Pratchett (AT LAST, SIR TERRY, WE MUST WALK TOGETHER.)
I think you will need to share your read sequences from MCU or used software. Does reading from MCU what you previously read, work?
Regards, Ulysses
Announcement
