2018-05-25 8:54 AM
I am using EVAL-ST95HF board and would want to see the demodulated signal using the oscilloscope. There's a Test Point-ST1 on board. Is that the de-modulator output pin?
I have attached an image for your reference.
Looking forward to hearing from you soon.
Thanks,
Preetha
#st95hfSolved! Go to Solution.
2018-06-04 2:18 AM
Hi Preetha,
No, there are no way to get the demolutator output on the boards.BR
PB
2018-05-31 4:54 AM
Hello Prethaa,
Unfortunately this IO is not the demodulator output and their are no pins that reflect in functional the internal signal.RegardsPB
2018-05-31 5:44 AM
Hi Peter,
Thanks for your reply. Is there any method to check the demodulator output (using software)?
Thanks,
Preetha
2018-06-04 2:18 AM
Hi Preetha,
PB
