What is the required input voltage (V_I(ON)) for ULN2001A?
kevindarmstadt
For the ULN2002, ULN2003, and ULN2004 the datasheet gives detailed information depending on the continuous collector current, but no such info is given for the ULN2001.
Peter BENSCH
Welcome, @kevindarmstadt​, to the community!
There is a simple reason for this: the ULN2001 is a simple multichannel bipolar Darlington transistor, whereas ULN2002...2004 each have a series resistor at the base.
The ULN2001 is therefore driven like an npn transistor, except that it has two base-emitter junctions in series, as is usual with Darlington.
You will find the differences in fig 1 on page 3 of the data sheet.
Does it answer your question?
/Peter
