2026-04-30 4:32 AM
Hello to all,
I am looking for the min-max humidity working ranges of the STTH10002TV1 diode (in %) as I can't find it in the product specification.
Is there a general value for all the ST's diodes? If so, where can I find it ?
Thank you for your time,
Best regards,
2026-05-04 12:42 AM
Welcome @Ludovic_Douillard, to the community!
There is no maximum specified RH as an ambient condition during use, but you should avoid condensation.
Hope that helps?
/Peter
2026-05-04 12:42 AM
Hope that helps?
/Peter
2026-05-04 1:44 AM
Thank you Peter for the warm welcome and your answer!
Best regards,
Ludovic
