Problem with Discovery dSPIN L6470H
nelsonsantander000
Posted on August 17, 2014 at 05:12
I am installing the Discovery dSPIN L6470H, I just buy from Digikey, this is not detected by the application spinFamily Evaluation Software, it shows the red light error, I look for the firmware file, thanks
#l6470h-discovery-eval6470-disk
Enrico Poli
Posted on August 21, 2014 at 14:50
If the VS supply is not provided to the board it doesn't connect with the software.
Try to supply the VS input and reset the board, then the 4 leds should start blinking in sequence and the board is ready.
Enrico
