MASTERGAN4L Radiation Tolerance
ryanbarn
I've been working with the MASTERGAN4L dev board to drive a transformer. This is for a purpose that will have to survive travel through deep space. I have a discretized roughly equivalent circuit made out of explicitly radiation tolerant / space rated components, but I know GaN is generally radiation tolerant, and I suspect I may be able to use the MASTERGAN4L and save a sizeable portion of board space. Do you have any information on the radiation tolerance of the MASTERGAN4L chips? Is there anything in the manufacturing process that you would identify as non-compatible with flight? There is also the possibility of customer-side radiation testing and space qualification.
0 REPLIES 0
