Disable L6924D maximum charging time
MLuca.2
According to datasheet, L6924D has the possibility to set a maximum charging time, defined according to the capacitor connected in TPRG pin. But what should be done if the maximum charging time limit is undesirable?
Can I short TPRG to GND to achieve an "infinite" capacitance, resulting in an infinite maximum charging time?
MLuca.2
Hey guys, someone knows what will happen if I short TPRG to GND? The L6924D will still work properly, without the maximum charging time limit?
Ruandj
Anyone with an answer to this forum question yet?
