buck-boost AC-DC convertion
carlo
Posted on February 24, 2014 at 15:45
Good morning,
we are looking for an configuration for our application LED driver.
We are taking a look among your AN, for L6562 designing in buck-boost config.
In the AN3111, at pg8, there is a not clear equation (equation 9). Wich is the value of Vpk? If Vpk is the value of the peak of Vin, the result of the equation 9...=108 is not clear.
For more details, read the files in attached.
Thank you for attention,
best regards,
Eng.C.Ammatuna.
#buck-boost-ac-dc
ramator
Posted on February 25, 2014 at 03:01
Good afternoon,
Your assumption is wrong.
You can see other open source
http://en.wikipedia.org/wiki/Form_factor_(electronics)
You can calculate Vave in the other way:
Vin
=120
VAC
Vpk
=1.4142
Vin
=169.7
VDC
Vave=0.637Vpk=108.1 VDC
Where you see a mistake?
Good luck!
