UART1 setting breakpoint problem
‎2013-06-25 2:00 AM
Hello all,
I am trying to make the chip to communicate with the PC. My code did not work and I want to debug the code. But I cannot control what happens when data is received. In the debug mode, the code never enters in the interrupt handler. How can I see what does the program do when it receives data from the PC?Thanks a lot in advance.Best regards,Gunay #usart #debug #interrupt #iar- Labels:
DEBUG
IAR
Interrupt
UART-USART
‎2013-06-25 5:08 AM
this is the part of the schematic which shows RS422 connections of the board.
-- I removed the schematic to prevent any trouble. I think clive1 and fm have seen it and found no problems (:I do not think there is a problem with these because it is a part of a well working board, at least it used to work well (: Is it possible to damage it with the code?- Mark as New
‎2013-06-25 6:38 AM
In theory, there is no problem, since PA8 and PA9 are denotes as 5V tolerant (assuming a F407). But I still don't get how you connect, for instance, RX+ and RX- on RS422 side to RX and GND on UART side. RS422 is differential, that means, RX+ to RX- is max. 10V. That would be too much for a GPIO input ...- Mark as New
‎2013-06-25 7:02 AM
I think the transreceiver IC does that part. I mean I do not connect GPIO pins of the chip directly to the Rx+ and Rx- but there is this IC between them. It's a TI component written ''05C8L6K VP1793 G4'' on top of it but I could find no datasheet available on the internet.
‎2013-06-25 7:22 AM
Finally, the RX pin of the STM32 needs to see a signal according to the RS232 standard (on CMOS level), and according to the configuration parameters (baudrate, databits, stopbits, etc.) to receive anything.
I deem it rather essential that this is the case - and a scope is the best tool to check this.- Mark as New
‎2013-06-25 7:41 AM
OK, I will test it with a scope tomorrow and post the results. But do you mean STM requires RS232, and its RS422 incompatible?
‎2013-06-25 8:02 AM
The physical layer differs, i.e. the voltage levels on the line. Assuming otherwise identical parameters (baudrate, polarity, character settings), they are compatible. With proper level shifting, it should work.
‎2013-06-26 8:24 AM
Hello guys,
Today I used a scope and found out that the problem is a really silly one. Connector cable was connected wrong, after changing it, problem disappeared. I apologize for taking your time for such a mistake.Thank you so much for your help.Best regards.Günay- Mark as New
‎2013-06-26 10:05 AM
Never mind.
One engineering rule learned: question everything, and check everything you did.
- « Previous
- 1
- 2
- Next »
