2025-02-21 6:22 AM - last edited on 2026-01-05 4:30 AM by ELABI.1
I want to interface the ATWINC3400 Wi-Fi module with an STM32F7 MCU using SPI. Has anyone successfully done this before?
If yes:
What are the key steps to make it work?
What modifications are needed in the driver files?
Any example projects or guides available?
I’d appreciate any guidance on getting started.
Thanks!
2025-02-22 4:31 PM
Here you can find help with your project: https://www.fiverr.com/categories/programming-tech/electronics-engineering/embedded-systems-iot?ref=platform%3Astm32
