I want to select a controller to design a energy meter. Is it necessary that controller should have EEPROM memory in built?
PKuma.12
I am really confused that is it necessary or not. Because if I am going to the series STM32F030 these controller doesn't have in built EEPROM memory.
Perhaps you work with someone who has a better grasp of the project requirements and specific use cases?
If you have a value that is constantly changing, and must be remembered, I don't think FLASH is appropriate, at the very least it is not the best choice.
6 REPLIES 6
Perhaps look at using the L0 series parts instead.​
PKuma.12
My question is that could I used a controller without EEPROM for my application?
PKuma.12
Yes as because it is energy meter so its value will be continuously change.
so you mean that EEPROM must be present to store values?
No, I'm saying that FLASH is perhaps the least suitable. Data could be journalled, and spread across multiple pages, to mitigate wear and failure.
Perhaps think about NVRAM (RTC/BKPRAM)
What design choices are driving the use of the F0 over the L0 parts?
PKuma.12
As because of the cost reduction.
Thank you for the answer.
