Hello, I´m not able to uncompress this file: File: en.stm32-mat_target.zip Filesize: 19.047.669 Bytes Installation File: STM32MatTarget_4.4.2_setup.exe What´s wrong with me or the file? Cheers Udo
UJuer
5 REPLIES 5
JWest.17
I'm having the same issue. Did you find a work around?
Test the integrity of the file, check that you don't have AV software interfering with the un-packaging.
Download works fine here, look for issues at your end.
MD5 : 84bd587e84a62c1d518ae85fccbb0151 stm32-mat_target_v4.4.2.zip
UJuer
I used 7-Zip and it worked.
Using WinRAR here, integrity test passes, file unpacks and executes.
Cyril FENARD
Hi @Community member​ ,
The version 5.1.0 of STM32-MAT/TARGET has just published end of July 2019.
The packing and installation have been revisited in this version.
Hoping that your installation is easier now.
Regards.
Cyril
