Worry about Sdip case of ST7
marco32
Posted on June 08, 2005 at 08:42
marco32
Posted on June 06, 2005 at 06:16
We heard there's a lot off delevery problems with Sdip32 case of ST72C245 and ST72F264? [In the Netherlands]
Today there isn't a problem with ST72C334, but it can be!
Anybody knows also of this problem?
Means this, the Sdip case will be obsolete?
That will be a big problem for us.
Moppie
[ This message was edited by: Moppie on 06-06-2005 09:47 ]
jps
I Moppie,
I haven't heard about your problem in france.
The best solution for you is to ask your local dealer !
In any case, if the Sdip case become obsolete you will have two choices :
1 - you redraw all your cards with an active package !
2 - you could maybe make a little PCB to adapt a Smd case on your existing board using Dip case ?
Whitebull
