Unable to access TPM ECC CA Certificate http://secure.globalsign.com/stmtpmeccint01.crt
DMait.1
I am trying to programatically validate the tpm cert.
I extract the URL from tpm certificate http://secure.globalsign.com/stmtpmeccint01.crt.
  Certificate:
   Data:
       Version: 3 (0x2)
   Signature Algorithm: ecdsa-with-SHA256
       Issuer:
           commonName               = STM TPM ECC Intermediate CA 01
           organizationName         = STMicroelectronics NV
           countryName              = CH
          X509v3 Basic Constraints: critical
               CA:FALSE
           X509v3 Extended Key Usage:
                2.23.133.8.1
           X509v3 Key Usage: critical
               Key Agreement
           Authority Information Access:
                CA Issuers - URI:http://secure.globalsign.com/stmtpmeccint01.crt
I get HTTP error 404 not found when i access the url.
BHOUY.1
​Your extraction is correct http://secure.globalsign.com/stmtpmeccint01.crt  is the  is good url. HTTP error comes from probably temporary network issue. Could you try again ?
Best Regards,
Benoit
BHOUY.1
​Your extraction is correct, http://secure.globalsign.com/stmtpmeccint01.crt is the good URL. Actually, link works, You met probably temporary network issue. Could you try again ?
Thank in advance,
Best Regards,
Benoit
