STR9 ComStick Can Question
ermal
Posted on July 30, 2009 at 17:20
ermal
Posted on May 17, 2011 at 09:59
Hello Gents and Ladies
I recently bought this module and been playing with it for a little.
According to SCM-STR912CS-A1-1a.pdf the can transceiver already has a 120ohm terminating resistance for the can driver.
Is there any way to disable this resistance since i want to use the module to listen to a can network that already has both terminating resistances.
If not what are my options?
Can i use an external can transceiver and transfer the functionality of the Can Rx and Can Tx to other pins. This module is already limited with 12 I/O's
Any help will be appreciated.
My Best Regards-
