STR9 Anglia Eth
szikaka
Posted on January 29, 2007 at 18:19
STR9 Anglia Eth
szikaka
Posted on May 17, 2011 at 09:35
hello
I'm trying to run Eth demo compile with Anglia (um0248) on MCB-STR9, program compiles and runs, phy led blinks but httpd or arp doesn't work. Is anybody here who can help me run this demo or have working sample which I can compile and after flash programing it will work properly?
sorry for my english
best regards
lukasz
nowydag
Hi
I just run surces STR91x_webserver_v1_1 on Keil compiler. Oryginal sources I couldn't compile because they are write to IAR compiler. I used modified files by 'acorchia' (
http://mcu.st.com/mcu/modules.php?mop=modload&name=Splatt_Forums&file=viewtopic&topic=4472&forum=21
Taste these sources.
Did You modify oryginal files for Anglia?
Best regards,
Marcin
PS.
Mam tez inne zrodla dziajajace pod Keilem do obslugi Ethernetu na ta plyte.
Napisz na nowydag(malpa)tlen(kropka)pl to podesle.
