STR7x Bootloader using bank1
ico74
Posted on January 04, 2007 at 05:45
4 REPLIES 4
ico74
Posted on December 21, 2006 at 18:13
Hi All!
Is it possible to update whole Bank 0 memory via bootloading program previously programmed to Bank 1? Is it possible to make such organization?
If No, why?
I think not, but I just want to be sure.
Thanks in advance.
Hristo.
kaouther
Posted on December 22, 2006 at 10:41
could you please precise which STR7x product are you using?
Thanks,
ico74
Posted on December 27, 2006 at 06:34
I'm using STR711FR2 microcontroller.
jgoril
Remember, it is not possible to boot directly from bank 1. So you need some piece of code stored also in bank 0. I think... you can use bootloader stored in bank 0 that will copy itself into RAM, then erase flash bank 0, and finally write bank 0 with new content...
Jozef
