2025-08-12 12:15 AM
hi,
I start to use STM mcu to develop power electronic circuit and software , I find the following stuff " STEVAL-DPSTPFC1 3.6 kW PFC totem pole with inrush ......." is the best reference design to me for learning , would you please deliver its schematic and source codes to me for study ?
as early as possible.
thank you.
Bob
2025-08-12 12:46 AM - edited 2025-08-12 12:47 AM
Welcome @bobjeng, to the community!
For security reasons, only the binary file is provided for such high-power applications, not the source code.
You are welcome to get in touch with your local distributor or sales contact who will help you realise your project if the quantity is large enough.
Good luck!
/Peter
Good luck!
/Peter
2025-08-12 6:11 PM
hi Peter,
thank you for reply.
2025-08-15 12:18 AM
I fully understand. But to make sure you understand everything as well, here are the details again:
For security reasons, no source code is provided for high-power boards such as this one. The community cannot help you, but the distributor in your region may be able to.
/Peter
