ST9 INTERUPT FOR SCI
gumina
Posted on February 22, 2006 at 06:59
gumina
hello to all,
it is my first post that shipment.
I have a problem with the ST9 F120, I am trying to create a software that to every data received on the serial me kinds a interrupt.
I have connected the ST9 to a hyperterminal I am through SCI1(9,1,9,0), SCI0(5,2,5,1); digit on hyperterminal the SCI0 I would want that it generated a interrupt and that me correspondent to SCI1 wrote the characters on an other hyperterminal but unfortunately this does not happen could even help me with a small code of example? I enclose you mine more soon main and rows SCI.C aspect to yours news thanks
MAIN.C
void main(void)
di();
INIT_PLL();
INIT_SCI();
INIT_SCI1();
INIT_SCI_IT();
ei();
spp(P0C_PG);
P0C2R = 0x00;
P0C1R = 0xFF;
P0C0R = 0x00;
P0DR&=0;
while(1)
INIT_SCI_IT();
ei();
spp(P0C_PG);
P0DR &= 0x0;
P0DR ^= 0x2;
spp(SCI0_PG);
ToRec=S_RXBR;
if (ToRec != temp)
spp(SCI1_PG);
S_TXBR=ToRec;
temp=ToRec;
spp(P0C_PG);
P0DR ^= 0x80;
SCI.C
#include ''sci.h''
#include
#include ''io_port.h''
#include ''define.h''
#include ''device.h''
#include ''ioinit.h''
#include ''string.h''
unsigned char ToReceive;
unsigned int c=0;
void INIT_SCI(void)
spp(SCI0_PG);
S_BRGHR = (unsigned char)((SCI_BRGENERATOR & 0xFF00)/256);
S_CHCR = SCI_CHAR;
S_CCR = SCI_MORECLOCK; /*CCR register: TXCLK = OCLK = XRX = CD = 0 */
S_ISR = 0;
S_IDPR = 0;
S_BRGLR = (unsigned char)(SCI_BRGENERATOR & 0x00FF);
IN_TTL(PORT_SCI0_IN, PIN_SCI0_IN);
OUT_AFPP(PORT_SCI0_OUT, PIN_SCI0_OUT);
void INIT_SCI1(void)
spp(SCI1_PG);
S_CHCR = SCI_CHAR;
S_ISR = 0;
S_IDPR = 0;
IN_TTL(PORT_SCI1_IN, PIN_SCI1_IN);
OUT_AFPP(PORT_SCI1_OUT, PIN_SCI1_OUT);
void INIT_SCI_IT(void)
spp(SCI0_PG);
S_IVR = (IT_SCI_VECT & 0xF8);
S_IDPR &= SCI_MASK;
S_IDPR |= PRIO_SCI;
S_IMR &= SCI_MASK;
S_IMR |= Sm_rxdi;
#pragma interrupt INTSCI_Receive
void INTSCI_Receive(void)
#ifdef NO_SAVE_RESTORE_PPR_IN_IT
SAVE_PAGE;
#endif
spp(SCI0_PG);
ToReceive=S_RXBR;
spp(SCI1_PG);
S_TXBR=ToReceive;
spp(SCI0_PG);
S_IMR &= ~Sm_rxa;
S_ISR &= ~Sm_rxap; /*clear pending bits*/
S_IMR &= ~Sm_rxdp;
RESTORE_PAGE;
#endif
di();
