RTC Clock/Battery failure
firmware
Posted on May 18, 2007 at 07:27
firmware
Posted on May 17, 2011 at 09:43
Hi to everyone,
I'm using a STR912FM44 mcu. Is there the possibility to check if the clock or the backup battery for the RTC have failed? I looked into the manual and the datasheet but I havent found anything about this topic.
Can you help me?
Regards.
massimo.
