Raisonance RIDE 7 compatibility with STR91xFWxx and STR91xF
jemondsalt9
Posted on April 24, 2009 at 04:08
jemondsalt9
Posted on May 17, 2011 at 09:58
I would like to know if it possible to use Raisonance Ride 7 compiler for controller STR91xFAWxx. When I go in ride 7 options, I can select a STR91xFWxx device but not a STR91xFAWxx (char “A� is missing). Is it compatible?
Thanks in advance,
Julien.
vincentchoplin9
Yes, you can work with the ''A'' device by selecting the ''non-A'' equivalent in Ride.
Upon connection, Ride will automatically detect that you have a ''A'' version and act accordingly when (if) it makes a difference.
Best Regards,
Vincent (Raisonance)
jemondsalt9
Thank you for this quick and clear answer !
Julien.
