2005-03-23 3:10 AM
Programming ST7 FLASH with External master controller
2005-03-21 8:09 PM
Hi Everybody
I am using ST72F324L. This controller is a part of bigger Design and I want to burn the ST7 FLASH through master MCU. Can I do it? and How? Regards HKobi2005-03-22 4:53 PM
You can use the IAP functionality which is easier to implement OR emulate the ICC programming.
2005-03-23 3:10 AM
Have a look at
. You can get readily available drivers.
