program does run correctly on DK3400
hanwayh
Posted on May 21, 2006 at 23:11
hanwayh
Posted on May 17, 2011 at 11:50
I wrote a bubble sort program for uPDS3400 and got it work on simulator. The program copied an array of 30 8-bit integers from program memory to XDATA memory and then sort the array in XDATA memory. However, when I downloaded the program onto flash memory, the contents of XDATA memory did not show correct result
