M24C04-DRE
AJian.2
I saw two version of subjected item at EE marketing , ​ is different on body marking , one is 404RP, the other is 404RB, so I would like to know the distinguish between them on electrical parameter? can alternative to use?
Pierre P.
404R8 is for range 8 ( M24C04-DRE)
404RP is for range 6 ( M24C04-RDW6TP)
Not the same temperature range / not the same die / not the same performance.
BR
Mr.
Could you please share the specification data sheet for the two model 404R8 and 404RP, and explanation in details.
Pierre P.
