Loading image error
ewitt
Posted on September 18, 2006 at 13:32
Loading image error
ewitt
Posted on September 08, 2006 at 09:46
Hi @all,
I am using RVDK 2.1.
When I compile my project and try to load the new image into RAM when there is already an image loaded i get an error like this:
Existing image '' has addresses that overlap with the 'RAM' section
Failed loading 'C:\Documents and Settings\ewitt\My Documents\p2d\ARM7filez\myproject\backup\example2\Debug\Example2.axf'
I did not have the problem before. Now i am getting this error every time. The only solution is to deconnect the debugger, turn of the ARM connect again and then load the image.
any suggestions?
cheers,
Erwin
ewitt
Thanks! this hint saved me a lot of time :)
