Is this code must be executed from ram?
k_arthur
Posted on May 18, 2007 at 08:55
k_arthur
Posted on May 17, 2011 at 09:43
RAM_exe void Execute_STR9Application(void)
pFunction Jump_To_Application;
/* Configure bank 0 as 512KB and bank 1 as 32KB */
/* Remap bank 0 at address 0x0 and bank 1 at address 0x80000 */
FMI->BBSR = 0x0;
FMI->NBBSR = 0x6;
FMI->BBADR = 0x80000 >> 2;
FMI->NBBADR = 0x0 ;
/* Jump to the user application and execute it */
Jump_To_Application = (pFunction) 0x00;
Jump_To_Application();
} void Execute_STR9Application(void)
FMI->BBSR = 0x0;
FMI->NBBSR = 0x6;
FMI->NBBADR = 0x0 ;
Does RAM_exe - means that this code must be executed from RAM ?
k_arthur
Thank you Zouhair. How to make run the function from ram in KEIL?
k_arthur
Thank you Zouhair !!! I tryed to run the code example from IAP of STMicro,but jump operation steel not work. As you know i work in THUMB mode . May be to try it in ARM mode? Already i do not know what to do?
