Interrupt function in RAM, how to?
jomedfree2
Posted on February 08, 2010 at 13:34
the_noxx
Posted on May 17, 2011 at 10:00
Hi Joel,
you can place a function in RAM using
''void yourfunc(void)__attribute((section(''.data'')));'' as declaration of the function. With attribute section you can place functions to every section defined in your linker script file. More information on http://gcc.gnu.org/onlinedocs/gcc/Function-Attributes.html.
Don't forget to add ''-mlong-calls'' to your gcc-options.
